Nashua Area Radio Society › Topics In All Forums › Mentoring Forum › Newbie seeking assistance: Anytone radio
- This topic has 8 replies, 2 voices, and was last updated 2 years, 3 months ago by
November 12, 2023 at 1:19 pm #155130
I am getting back on air after 50 year lapse. Trying to do codeplug for my Anytone HT. When I upload to radio, some channels are OK and others are skipped. So far only trying FM analog, not DMR. Used both Anytone software and RT Systems software with same result. Can anyone help? Thanks.
November 12, 2023 at 6:32 pm #155131Hi, Varel.
When you say, “skipped”, what do you mean?
Do you mean when scanning, some frequencies are skipped, or do you mean when programming, some frequencies are not programmed into the radio, or something else?
November 13, 2023 at 4:23 pm #155155
Ted, The code plug spreadsheet will show a list of channels that are programmed—in my case chans 1, 3-10. The radio, after download from the programming software, will show fewer channels as programmed…channels 4, 9, 10 are blank. In this case all are FM analog channels–I haven’t graduated to digital yet. Behaviour is the same with both code plug softwares. I have done a reset to factory default, download the basic code plug from the radio into the software, entered new channel info and uploaded to radio with the same results. Any insight is appreciated!
73, Varel
November 13, 2023 at 4:56 pm #155156Hi, Varel.
Thanks for the explanation. Would you mind if I took a look at your code plug? You can attach it here, or email it to me [email protected] .
November 14, 2023 at 3:43 pm #155163
Attached. Will also email. Much appreciated for the help.
November 14, 2023 at 3:49 pm #155164
Hmm..it would not let me upload the AnyTone software code plug. Trying the RT Systems plug.
November 14, 2023 at 3:50 pm #155165
Ted–couldn’t upload here. I have emailed you both plugs–AnyTone software and the RT Systems plug. Thanks, Varel
November 15, 2023 at 11:53 am #155167I’m hoping that the solution we discussed via email worked for you!
Please check out this list of DMR nets: DMR Nets – NEDECN
It’s a great idea to check-in to the Monday night New England DMR net. It’s a great way ind out what’s going on and confirm your radio is programmed correctly at the same time.
November 15, 2023 at 11:54 am #155168
Hats off to Ted for solving the mystery! The assistance is much appreciated.
