ISS SSTV August 6-7 2021 @ 145.800 MHz FM
Nashua Area Radio Society › Topics In All Forums › On The Air Forum › ISS SSTV August 6-7 2021 @ 145.800 MHz FM
  • This topic is empty.
  • #133073
      The video Ham Radio and Linux – Using QSSTV to decode from captured audio files inspired me to look more into trying to receive slow scan TV from the ISS.
      From Southgate Amateur Radio News we see there will be ISS SSTV activity in the near future:
      ISS SSTV Aug 6-7 145.800 MHz FM
      Russian cosmonauts on the International Space Station (ISS) are planning to transmit Slow Scan TV images on 145.800 MHz FM using the SSTV mode PD-120
      The transmissions are part of the Moscow Aviation Institute SSTV experiment (MAI-75) and will be made from the amateur radio station RS0ISS in the Russian ISS Service module (Zvezda) using a Kenwood TM-D710 transceiver.
      August 6, 2021 (Friday) from 10:50 GMT until 19:10 GMT*
      August 7, 2021 (Saturday) from 09:50 GMT until 15:55 GMT*
      *Dates and times subject to change.
      The signal should be receivable on a handheld with a 1/4 wave whip. If your rig has selectable FM filters try the wider filter for 25 kHz channel spacing.
      You can get predictions for the ISS pass times at
      https://www.amsat.org/track/
      ARISS SSTV Blog
      https://ariss-sstv.blogspot.com/
      Useful SSTV info and links
      https://amsat-uk.org/beginners/iss-sstv/
      It says only a whip antenna is needed. I think I will make a simple one like this and deploy it either here at my home QTH or at MakeIt Labs in Nashua.
      I have a couple different SDR dongles that can receive 145 MHz, either the widely available RTL-SDR dongle or AirSpy Discovery HF+. I probably will go with the last one, it is the best receiver of all of them.
      Let me know if anyone else is going to give this a go, it should be fun!
