In the article on Fox-1D, AO-92, I mentioned that this satellite has a QVGA resolution camera aboard. Here are a couple pictures from it. The picture that is mostly clouds is north up (approx) with Bermuda on the right and Florida on the left.
The picture with mostly land is, to me, the most impressive. Although it was originally south-up, I inverted it so what you see is approximately north-up. The big water feature is the Gulf of Mexico with the Florida panhandle to the north and the main part of Florida to the east. You can see the Suwanee River clearly toward the east, and Alligator point on the north-western side of the picture. Again, all the pictures are available at the URL below, and a sched will be set up after commissioning for when the camera will be on (the repeater function is off when the camera is on–it takes the full bandwidth of the downlink to send pictures down)
You must be
logged in to view attached files.
Oh, I forgot to mention that the little line/knob on the top of 1 picture and the bottom of the other is the end of the receive antenna with a bit of melted fishing line tied to it. The fishing line holds in against the satellite during launch and is melted after the bird is released in orbit.
