Good Evening!
Last night I wanted to change the cable connecting my Vibroplex Codewarrior Jr. from ¼” to ⅛” jack. I received both cables when I got the paddles. I took the original cable off and then got called away and, foolishly, forgot to document which connector went to which terminal. Just to make it a little less clear both cables have different color conductors.
¼” has blue, white, and bare copper
⅛” has red, white, and yellow
Does anyone know the correct placement for each of these cables?
Thanks!
Harry Mueller, W1HMM
Durham NH
Use an ohm meter to ring out the conductors.
I was able to borrow a multimeter (mine is broken) and check continuity on each conductor.
- tip=dit
- ring=dah
- sleeve=ground
They’re labeled now.
Harry
