Validating EchoLink
  • #53218
    Hello all!
    I am one of the newest members of the NARS and I initially had a problem with EchoLink that I fixed. I heard that some of the other new students were having this exact same problem so I wanted to bring up how to fix it!
    The process is extremely simple: First, if you have not already, set up an account with EchoLink and register your callsign in it. When you first setup the account you should get an error message saying that your callsign was not validated. This is the problem I encountered. When you see this message, go to http://www.echolink.org/validation/ and input your call sign. From there, the website will instruct you what to do and will verify you, allowing you to use EchoLink
    (I highly suggest you do this on a computer)
