Plans for WSJT-X 2.0
  • #52378
      Looks like a new, major release of WSJT-X is in the works. Note the additions for Field Day and for the ARRL RTTY Roundup. Also, note the “Telemetry Mode” additions – perhaps something for a future long-range HAB? For the following URL to read the original version (or scroll left/right to read it as attached here) –
      http://physics.princeton.edu/pulsar/k1jt/wsjt-x_v2.0.txt
      Fred, AB1OC
      			Plans for WSJT-X Version 2.0
      This white paper describes a number of important enhancements planned
      for WSJT-X Version 2.0.  Most of them involve the FT8 and MSK144
      protocols, which will be upgraded to use 77-bit information
      payloads rather than the present 72 or 75 bits.  This modest increase
      in information content will make possible new message types that
      support the following special types of QSOs and exchanged information:
      1. NA VHF Contest operation with full and transparent support of grid
         locators and "/R" (Rover) callsigns
      2. EU VHF Contest operation with the exchange of 6-digit locators, QSO
         serial numbers, and "/P" (portable) callsigns
      3. ARRL Field Day operation with standard Field Day exchanges
      4. ARRL RTTY Roundup operation with standard contest exchanges
      5. Better and more user-friendly support for compound and nonstandard
         callsigns
      6. A special "telemetry" message format for exchange of arbitrary
         information (up to 71 bits)
      Decoding sensitivity for the new messages will be essentially the same
      as for the FT8 and MSK144 modes presently in WSJT-X v1.9.1.  The
      existing FT8 DXpedition mode will still be supported, and a more
      powerful DXpedition mode may be offered as well.
      In this document, we'll call the new FT8 protocol "FT8+".  It will be a
      superset of the FT8 implemented in v1.9.1, providing at least
      temporary compatibility and interoperability with older program
      versions.  We may decide to remove support for old-style 72- and
      75-bit messages after a specified switchover interval.
      In contrast, the new MSK144 protocol will replace the old one without
      backward compatibility.  We believe the smaller and more specialized
      group of MSK144 users will upgrade quickly and not find this
      restriction to be a problem.
      Here are some examples of message formats that will be supported by
      FT8+ and MSK144 in WSJT-X v2.0.  The list is not exhaustive.
      Parameters i3 and n3 (shown in column 1) are used in the software to
      define major and minor 77-bit message types.
      i3.n3     Example Messages                    Comments
       0.0      TNX BOB 73 GL                       Free text
       0.1      K1ABC RR73; W9XYZ <KH1/KH7Z> -08    DXpedition Mode (sent only by Fox)
       0.2      G4ABC/P R 570007 JO22DB             EU VHF Contest
       0.2      PA9XYZ 590003 IO91NP                EU VHF Contest
       0.3      K1ABC W9XYZ 6A WI                   ARRL Field Day
       0.3      W9XYZ K1ABC R 2B EMA                ARRL Field Day
       0.5      123456789ABCD                       Telemetry (18 hex digits)
       1.       <PJ4/K1ABC> W9XYZ                   Compound call
       1.       W9XYZ <PJ4/K1ABC> 73
       1.       CQ FD K1ABC FN42
       1.       CQ K1ABC FN42
       1.       CQ TEST K1ABC FN42                  NA VHF Contest ("TEST" is optional)
       1.       CQ TEST K1ABC/R FN42
       1.       K1ABC W9XYZ EN37
       1.       K1ABC W9XYZ -09
       1.       K1ABC W9XYZ R-17
       1.       K1ABC W9XYZ RRR
       1.       K1ABC W9XYZ 73
       1.       K1ABC W9XYZ RR73
       1.       K1ABC/R W9XYZ EN37
       1.       K1ABC W9XYZ/R RR73
       1.       W9XYZ <YW18FIFA> -13                Nonstandard call
       1.       <YW18FIFA> W9XYZ R+02
       1.       W9XYZ <YW18FIFA> RRR
       1.       <YW18FIFA> W9XYZ RR73
       2.       CQ G4ABC/P IO91
       2.       G4ABC/P PA9XYZ JO22
       2.       PA9XYZ G4ABC/P RR73
       3.       K1ABC KA0DEF 559 MO                 ARRL RTTY Roundup
       3.       K1ABC W9XYZ 579 WI                  ARRL RTTY Roundup
       3.       KA1ABC G3AAA 529 0013               ARRL RTTY Roundup
       3.       TU; G3AAA K1ABC R 559 MA            ARRL RTTY Roundup
       3.       TU; KA0DEF K1ABC R 569 MA           ARRL RTTY Roundup
       3.       W9XYZ K1ABC R 589 MA                ARRL RTTY Roundup
       4.       CQ KH1/KH7Z                         Compound call
       4.       CQ YW18FIFA                         Nonstandard call
      Here are some examples of minimal QSO sequences that take advantage
      (where necessary) of the new protocol capabilities.  Model QSOs number
      1 and 2 are supported already, with the present FT8 and MSK144
      protocols, and number 3 with the existing FT8 DXpedition Mode.  Model
      QSOs 4-8 (and others not illustrated here) require the new protocols
      with 77-bit messages.
      1. Standard QSO
      CQ K1ABC FN42
                                         K1ABC W9XYZ EN37
      W9XYZ K1ABC -11
                                         K1ABC W9XYZ R-09
      W9XYZ K1ABC RRR
                                         K1ABC W9XYZ 73
      2. Short-cycle QSO
      CQ K1ABC FN42
                                         K1ABC W9XYZ -09
      W9XYZ K1ABC R-11
                                         K1ABC W9XYZ RR73
      W9XYZ K1ABC 73
      3. FT8 DXpedition Mode
      CQ KH1/KH7Z
                                         KH7Z K1ABC FN42
      K1ABC KH7Z -12
                                         KH7Z K1ABC R-14
      				   KH7Z W9XYZ EN37
      				   ... possibly other callers ...
      4. ARRL Field Day
      CQ FD K1ABC FN42
                                         K1ABC W9XYZ 6A WI
                                         K1ABC W9XYZ RR73
      5. ARRL VHF Contests
                                         K1ABC/R W9XYZ EN37
      W9XYZ K1ABC/R R FN42
                                         K1ABC/R W9XYZ RR73
      6. ARRL RTTY Contest
      CQ TEST K1ABC FN42
                                         K1ABC W9XYZ 579 WI
                                         K1ABC W9XYZ RR73
      7. EU VHF Contest
      CQ TEST G4ABC/P IO91
                                         G4ABC/P PA9XYZ JO22
      PA9XYZ G4ABC/P RR73
      8. Compound call
      CQ PJ4/K1ABC
                                         <PJ4/K1ABC> W9XYZ
      W9XYZ K1ABC -11
                                         K1ABC W9XYZ R-09
      W9XYZ <PJ4/K1ABC> RRR
                                         <PJ4/K1ABC> W9XYZ 73
      To minimize confusion that's likely to arise during a switchover from
      v1.9.1 to v2.0, we propose to follow a well advertised schedule:
      "RC1 Date"  --  perhaps as early as September 15, 2018?
      This will be the first chance for beta testers to try WSJT-X using the
      77-bit messages.  We may restrict this opportunity to specific
      volunteer testers, and we'll probably include an "upgrade by
      xxxx_date" message to remind people that they are using a release
      intended only for testing.
      FT8+ will support the old (v1.9.1) protocol as well as the new message
      types outlined above.  To avoid QRMing legacy FT8 users with messages
      they can't decode, we'll recommend testing FT8+ on frequencies
      formerly used for JT9.
      MSK144 will be fully functional between any two stations using the RC1
      software, but it will not be backward compatible with earlier program
      versions.
      "RC2, RC3,... Date"  --  perhaps in October?
      As needed, depending on results of testing.
      GA Release Date      --  perhaps in November?
      Official General Availability release of WSJT-X v2.0.0.  The original
      MSK144 protocol will be declared obsolete.
      For reference: Dates of relevant upcoming ARRL contests
      VHF QSO Party:   September 8-10, 2018
      RTTY Roundup:    January 5-6, 2019
      VHF SS:          January 19-21, 2019
      Our proposed schedule should make WSJT-X Version 2.0 usable for
      relevant ARRL operating events in 2019.
