The latest firmware displays battery level, but requires a diode (PN# SD103AWS) to be added in position D2. This diode was called D1 in the original schematics by edy555, and is D2 in the schematics provided by hugen79 (attached). After a little digging, it turns out that the NanoVNA designs being marketed today (edy555, hugen79, and clones) are based on the hugen79 schematics.
Technically then, if one wanted to buy a NanoVNA from the designer, instead of a cloned design, that would be here: https://www.alibaba.com/product-detail/Hugen-NanoVNA-H-New-item-Original_62342877955.html
I don’t have experience purchasing from this location. Does anyone else? It certainly looks like a nicely packaged product.
Note that NanoVNA-H is the designation worked out between edy555 and hugen79 to differentiate the new design from the original design. It appears that both designers are now supporting the NanoVNA-H design.
Regards,
You must be
logged in to view attached files.
