Dear Forum:
Does anyone have ideas on the lowest-noise solution to get 12V down to 5V? I have a FlexRadio and an SDR/Raspberry Pi monitoring UHF in my attic. I recently changed back to a linear power supply and am trying to get rid of some wall warts. The Raspberry Pi runs on 5V/2.5A.
Thank you!
Are you talking about homebrew? An LDO regulator (not a switching one).
Don’t know if its considered “low noise,” but I’m betting this one would be quieter than a wall-wart:
https://www.adafruit.com/product/1385
I’ve also got myself a bunch of smaller buck converters, but the link above is good for up to 3A output at 5V.
If you want an off-the-shelf solution, it would be a DC-DC converter module. They’re available from major electronics distributors such as Digi-Key and Mouser. They’re usually small rectangular modules with pins meant for a PC board, so you’d mount yours in your equipment with double-sided tape, and solder wires on.
The ripple at the switching frequency might be higher than you want, but an LC pi filter downstream can attenuate it to a millivolt peak-to-peak or less, at the cost of degraded transient response.
Caution: download the PDF data sheet before selecting the module you want, and read it carefully. Some DC-DC modules require external components for stability or ripple reduction. I would usually install a transient voltage suppressor across the input, to prevent resonant overcharging due to the inductance of the lead wires when plugging into a live voltage source.
Jack Carroll W1PK
