Thanks to (sorry I don’t remember who) brought those LED emergency lights to the meeting to give out.
I believe he said they ran on 3.3V. Just for information’s sake, they draw about 1 amp (!) at 3.3V and are very bright!
Thanks again,
Burns W2BFJ
I brought them in and I may have more in the future.
They run on 3.6v and I think that you can run them up to 14.4v if you wire 4 of them in series. I have not yet tried this.
You can always use lower voltages to achieve higher lumens per watt.
Thank you! And thanks for the voltage info. I remembered 3.3. No doubt at 3.6 it uses a bit more current also. So these are roughtly 3+ watts, but they sure have a lot of lumens!
