Nashua Area Radio Society › Topics In All Forums › Mentoring Forum › ICOM-7300 -FT8 Issue of USB-D going to USB on transmit
- This topic has 4 replies, 3 voices, and was last updated 5 years ago by
Peter Wolczko.
April 1, 2021 at 12:03 pm #117437
Lately, while on FT8, the mode SSB mode changes on it’s own, when the 7300 goes from receive to transmit. The USB-D changes to USB. I have to manually reset the mode to USB-D during transmit. No clue as to what may be causing this problem.
Any ideas of what it might be?
Thank you,
73, Peter KC1FNF
April 1, 2021 at 12:13 pm #117442Hi Peter,
You might check all of the transceiver interface settings in WSJT-X. Make sure you are using “fake-it” and that WSJT-X is configured for the IC-7300 and you are using the CAT interface for PTT. Also, make sure that the Mode setting is set for “Data/Pkt”. You should also be using 8 data bits, one stop bit, and no handshake. Finally, make sure that you are not forcing any of the control lines.
You should also check that you don’t have any other software (loggers, etc.) that is trying to interact with the radio at the same time. The best way to test for this is to stop all programs that might be using the radio EXCEPT for WSJT-X and see if the problem is still there. If it goes away, then you probably have another program trying to manipulate the radio at the same time as WSJT-X.
I hope that this helps.
April 1, 2021 at 12:50 pm #117463FRED,
Your information solved my ICOM-7300-FT8 problem. Fantastic!
I had to change the following on WSJT-X:
Radio Settings From To
Data Bits Default 8
Stop Bits Default 1
Handshake Default None
I just confirmed that I had it corrected, as I made contact in Colorado and the software did it all.
Many thanks,
73, Peter KC1FNF
April 1, 2021 at 2:24 pm #117506Check your Connectors settings on screen 2/4 DATA OFF MOD set to MIC and DATA MOD screen 3/4 set to USB.
Tom Mahon
AB1NSApril 1, 2021 at 5:08 pm #117534Tom,
I appreciate the info. I verified that I now have all of the correct settings. Those settings you referred to were set, as I had checked previously.
I now have FT8 working as it should.
Thank you very much.
73, Peter KC1FNF
