IC-7300 Keyer settings
  • This topic is empty.
  • #142972
    Hello,
    When I key my right paddle, the -7300 produces a dit-space-dit response instead of the correct Dah.
    The settings in the CW-Key Settings menu appear to be correct.
    Any recommendations on what other settings could be changed to correct this issue?
    Ryan
    #143363
    Benjamin MartinBenjamin Martin
      Hi Ryan,
      I believe that I had the same issue on the IC-7300, and without thinking of it much I simply switched the wires that were connected to the keyer. (e.g. reversed the dit and dah)
      Is that an option for you? Or are the wire connections internal to the keyer? (i.e. hard to reconfigure?)
      Ben W1BPM
