Euipment Jumper Cables
  • #98867
      I use LMR-400 coax with PL-259 and SO-239 connectors for my HF ZS6BKW and vertical VHF/UHF Comet GP9 antennas. The LMR coax is rather stiff and difficult to disconnect/reconnect when testing or moving gear. What size coax with the same PL and SO connectors is recommended from e.g., a radio/antenna switch to equipment to minimize noise or performance loss?
      73, Duane  KD9LIL
      #98872
        Hi Duane,
        I use RG 8X for all my HF connections, including 6M, much more manageable than LMR 400. For VHF/UHF you may consider LMR Flex. I live with LMR 400, terminating at window antenna feed thru and then for the short jumper to the Xcvr i use RG8X.
        73 de k1jbd
        bammi
        #98890
        Burns FISHERBurns FISHER
          Don’t forget there is LMR400UF which is a bit more flexible.  (UF is ultraflex, not underground feeder like power cables 🙂 )
          Especially for 70cm, I use LMR400, and then the UF version when I need more flexibility, and occasionally I’ll go to something smaller for a short distance when it needs to take a turn.  But I try to use N-connectors whenever I can at 70cm, and when I am switching from one cable to another.  They have a lower insertion loss and better impedance characteristics.  The connectors are much less important at lower frequencies, though.
          73, Burns WB1FJ
