CW or QRP?
Viewing 7 posts - 1 through 7 (of 7 total)
  • #1662
      Please post some messages about QRP topics here.
      #1747
        When I first read the title of this forum I thought that maybe CW and QRP was a choice of one or the other.  Then I thought, ‘Nah, couldn’t be.’. I’ve been a member of NEQRP (The New England QRP Club) for several years now and almost every person I’ve met uses CW.  When you’re operating with 5 watts, usually considerably less, CW will make the trip when phone such as SSB can’t get through the noise.
        Last year I watched a friend make contact from Dover NH to Russia on about 3 1/2 watts.  Even that was probably more than he needed.  Another friend operates pedestrian mobile on the beach in Hampton NH.  With 3 or so watts and an antenna sticking out of his backpack he frequently contacts Europe.
        Check into it.  You may find that you don’t really need that new amp after all.
        #1765
          Thanks for posting Wayne. You are right, if you have a good antenna, you can go a very long way using QRP. Adding CW to the mix helps even more. One of my longest contacts ever was to Western Australia which is about 1/2 way around to world from here. I made it using CW and 5w. That works about to a little over 2,000 mi/watt.
          #1779
          Morse Code Rappers!
          #1782
          [attachment file=1783]
          #1785
            I have a shack too!
            #2450
            Has anyone used the AlexLoop magnetic loop for QRP?  If so with what effect?
