Not sure this is exactly about home brew–more like home hacking. 🙂
I have a Signalinc connected to the accessory port of my IC-9700 but I really wanted to use the +13.8V output of that to run a coax relay to swap an antenna to the 9700 when it is turned on. They never actually say the official DIN number of that 8-pin plug, and there are at least two DIN 8-pin formats So looking at pictures a ordered a MIDI splitter. (MIDI is Musical Instrument Digital Interface). Good news! MIDI cables fit fine! I also ordered a M/M MIDI cable, cut it in half, and hooked a powerpole connector to it. Now with the splitter I can get both the relay and the audio sent to different places!
If you do this, don’t forget a flyback diode across the relay coil to avoid a lot of back-EMF across the radio output!
73, Burns WB1FJ
A very creative and low-cost solution to a common problem Burns. Thanks for sharing this tip!
