Nashua Area Radio Society › Topics In All Forums › General Information Forum › 4 Foxes Loose in Nashua
- This topic has 3 replies, 4 voices, and was last updated 7 years, 9 months ago by
Frank Murphy.
June 30, 2018 at 10:42 am #48643
There are 4, yes 4, foxes loose in Nashua this weekend!
The large foxes (2) are transmitting on 146.595 and 146.565.
The medium fox is transmitting on 146.535 and the micro fox is transmitting on 146.505.
Please DO NOT CONTINUE READING if you don’t want any hints!!
All four foxes are located in Mines Falls Park in Nashua.
[attachment file=”Mine Falls Park Trail Map (PDF).pdf”]
All the foxes are very close to the trail – no bushwacking – and are within 2-3 steps of the trail. Since they are so close to the trail they are fairly well hidden, but if you are close look for obvious spots where you would hide a fox. Look for hollow logs or trees, a landmark that stands out or something that looks out of place.
You should be able to hear the large foxes from almost anywhere in Nashua. The medium one (146.535) should also be able to be heard from any of the other foxes. The micro fox (146.505) is much harder to hear. I could not hear it on my handheld (without a directional antenna) from 2 of the foxes, but could hear it from the fox that is closest to it.
If you want to borrow equipment or need more hints just post here and I will be happy to help out.
Happy hunting!
You must be logged in to view attached files.June 30, 2018 at 5:56 pm #48673Thanks for putting out the foxes Jamey! Wish I had time to chase them but ARRL cabinet meeting + 13 Colonies will keep me from the hunt this time.
Hope everyone has fun with the foxes!
July 1, 2018 at 12:10 pm #48692
Anonymous
Hunter’s Log-Sun Date 2018.0701
Located on large rock @ Sucker Field. No fox heard. Bribed 3 Chipmonks with granola bar. All died before coughing up info. Located 2 PokeMons. Both neutralized. Found one Groundhog. Invited him for dinner. Main course. He stole a granola bar and escaped. Still no Fox. Calling Scotty to beam me up????
KC1HDN
July 2, 2018 at 8:49 pm #48874Found “Fox zero” using rubber ducky antenna on Saturday afternoon about 1:30 PM. Hunted “Fox 1”, was very close, but could not see the Xmtr. I had it bracketed, looked high and low, but no joy. I was going to go back on Sunday, but changed my mind about hunting in the heat. Thank you Jamie for setting and collecting the foxes.
Frank, N1GDD
P.S. I didn’t see any other “hounds” while I was there.
